Screen flickering in fusion 360
nathanputnamonline
nathanputnamonline
Hi, i just installed fusion 360 and whenever i move the mouse or do anything the screen flickers, subtly, but enough to immediately cause eye strain.  i'm using a 144hz monitor at 1440p, GTX 1080, and i've already check for driver updates.
fusion is the only program where it flickers and it's making the program unusable.  with fusion open i can switch to any other program and fusion is still flickering in the background.
please help.
saito.kh
Autodesk Support
Autodesk Support
Hi @nathanputnamonline,
Welcome to the Fusion community!
Thank you for posting!  I am sorry to hear you are experiencing this issue.
Can you please try "disable the Display scaling on high DPI settings" in this article if you are running Fusion on Windows?
If you are using mac, you would please uncheck "Open in Low Resolution" in the same web site.
If this does not help, would you mind sharing the screenshot of the Graphics Diagnostic window so that I can check if Fusion is using the graphic and driver in the system.
Hopefully this helps.
If you have any questions, please let me know and I'm happy to help!
Thank you.
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
nathanputnamonline
So i went through the disable scaling steps in the article.  the latest windows update has changed that setting now so it's a different choice.
drivers are all updated.
I went into the settings and changed the graphics driver from auto select to directX 9, and that seems to have solved the problem.
thanks for the help
Thanks for this one, similar thing worked in Mac OS.
Type a product name
