Fusion Support
Revolve Not Working
6 REPLIES 6
alan
2909 Views, 6 Replies
Revolve Not Working
I have been using revolve for a long time and since the last update it doesn't appear to working.  Has there been any reports?  Please help.
6 REPLIES 6
HughesTooling
in reply to: alan
Works fine for me. If you have a design where it doesn't work can you share it here? Export as an f3d and attach
Mark Hughes
Owner, Hughes Tooling
alan
in reply to: HughesTooling
Thanks for the reply.  There is a file attached.
HughesTooling
in reply to: alan
I can revolve around any of the axis no problem. What problem are you having? Try restarting Fusion. One other thought, do you have all your selection filters enabled?
Mark
Mark Hughes
alan
Okay, I have tried several times and it would not work.  Now I have click on select box then select.  After that I have to click on the axis box and then select.  It use to be just click area and axis and it was done.  Oh well.  The other difference I've noticed is when I right click after an operation the "done" command is no longer available.  Progress??
HughesTooling
in reply to: alan
Can you make a screencast of what you're seeing. If there is only one profile available when you start the revolve command that profile will be autoselected, then you just select an axis. If I right clcik after selecting the profile and axis I have the OK option to accept.
Mark
Mark Hughes
HughesTooling
in reply to: alan
For me the select option is highlighted when I start the command so I just select the profile, then select axis on the dialog(always worked this way), then right click OK or press enter.
Mark
Mark Hughes
