Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Offset\Press Pull Bug?
2 REPLIES 2
HughesTooling
524 Views, 2 Replies
There seems to be a problem adding to a selection for offset after setting a distance. I'm sure in the past you could press Ctrl to suppress the offset then add faces, now you have to keep pressing and releasing the Ctrl button between each selection. Each selection goes straight to offset and you need to release the Ctrl key then press again. Hope the screencast makes it clear. With a zero offset you can add as many face you want.
Mark
Mark Hughes
Owner, Hughes Tooling
2 REPLIES 2
yup, that is a bug all right.  It used to work...  The bug is FUS-54789
Thanks for reporting it, @HughesTooling .  I can always count on you to report real bugs, with clear steps to reproduce...
Jeff Strater
Engineering Director
jeff_strater
in reply to: jeff_strater
follow-up:  This bug has been fixed internally, and will make its way through the pipeline to the outside world in due course...
Jeff Strater
