How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
My design will open, but Fusion hard crashes when I try to update the external references. All versions crash hard, and I have send many crash reports to Autodesk this morning. Hoping the community can help.
Problem happened when Fusion was running real slow, so I restarted my PC, and now all versions crash.
I also noticed that I dont get the get latest feature except in the top bar (not at component level)
Thanks...Henry
After trying a bunch of things to recover the file, here is what I found (not much)
"Get all latest" would crash 360 hard, and there was no option to just update the offending component reference in the main design, but I could when I opened the sub assemblies that contained the old components.
I thought there was a "get latest" when I right click on the out of date component, but in this case that option didnt exist, so I had to open its design separately and get latest there. That is fine by me, but "Get ALL latest" crashed fusion hard every time. When I updated everything myself bit by bit, I was able to get the design recovered, but had to delete some components in the process. Now I have to try to get those put back in to the main file again.
Unclear yet why the components all of a sudden became "outdated" for no reason (they were up to date at the time that I saved the project before restarting my PC) but I suspect Fusion got tripped up in its file handling somehow at the time that I shut down the PC.
In the end no answers, but at least things are kinda fixed...for now.
I downloaded your assembly and it looks spiffy clean!
I was able to open many of the sub-assemblies without a problem.
However when I opened the top level assembly Fusion 360 crashed, without be trying to update anything. Just opening the assembly!
@ryan.bales it would be good to check this out!
I'm getting the same thing. Crashes on open. I'm not sure how much i can provide to this one @HenryDara, does it crash for you on open?
Im not sure which version your looking at now, I was able to open it, but it crashed when I tried to Get All Latest.
I am now working on v141 ( https://a360.co/2DP1k3d ) having moved on, and it opens fine now that ive manually updated the references. It seems we are all getting different behaviors from the same file.
Thanks...Henry
After moving on, I had another kind of odd thing happen with this file...
Where the MCP needs updating, I do a Get Latest for just that component, and a bunch of joints go wacky that dont seem like they should be affected at all by the MCP as far as I can figure.
Anyhew, I was able to delete the MCP without getting any errors, then re-inserting it back into the main design, but then it would not let me joint it in the main design. Getting compute failed error (like I usually get when ive jointed something wrong somewhere)
Narrowed the offending feature in the MCP to a Body to Comp 1 (the MCP), which happens late in the timeline after all the modeling stuff, but before attaching and joining all the hardware to the new components (from bodies)
Is this where I went wrong, breaking rule #1? If so, is there any way to fix it besides remodeling the parts following rule #1 better? These days I always create the component first, but this was created prior to me doing that by default.
Thanks...HD
How to buy
Type a product name
