Fusion 360 makes me happy : it is very powerful and useful...
I tried to install Fusion 360.
I successed on my computer (windows 8)
I successed on another on (Ubuntu 16.04 + VMware), but it's not a good idea : it goes as fast as a snail.
I found an third computer (windows 8), but on this machine installation does'nt work
I need this in such a way as, the first computer is often used by everyone at home...
I put a screencast and the logfile below.
I precise that I'm french (sorry for my english writing) and I'm not so comfortable with computing.
I hope that someone will help me to understand this issue.
Franck.
Solved by julia.paganucci. Go to Solution.
Hi @Anonymous,
Welcome to the Fusion 360 community!
It looks like from your log file that you had a Connection Refused Error. This usually happens when there is a problem with the server Fusion is downloading from. Can you try following the steps in this article under the "If you see "Connection refused" in your error text or log file" section? If that doesn't work you can try working through the suggestions in this other article here.
Let me know if you have any questions about this or if you are still unable to instill Fusion 360!
Hi Julia,
thank you so much for your message.
Unfortunatly, I tried the two thinks you proposed....it is always the same thing.
I'm totaly lost.
Hope there is a thirds road to solve my problem.
Best regards.
Franck.
Hi @Anonymous,
I think you should try configuring proxy server and firewall for Fusion 360. Access to the online services for Fusion 360 is required, and a proxy server, firewall, or anti-virus software may be interfering with the normal operation. More information here. Once you do this, please reinstall Fusion 360.
If this still does not work, can you send me a new copy of your webdeploy.streamer.log? Thank you and I hope we can figure this out!
Hi Julia,
thank you for your responce. But Fusion 360 still not be installed.
I don't understand...any other idea on your end?
I let the log file as attached file.
Regards and happy new year!
Franck
Hi @Anonymous,
Thanks for the logs! I took another look am I'm still seeing some of the same errors. It's possible that there could be something blocking access to one of the sites needed for Fusion to function. This can appear as a proxy in the logs even though you does not use a proxy, which could be why I'm seeing this. Are you able to run a virus scan on your computer and delete any viruses or malware found? Then hopefully you can install Fusion 360 successfully.
Let me know,
Hi Julia,
my antivirus scanned my computer...nothing appeared.
Thank you for your help! I hope you (we) will find what's wrong.
Regards.
Franck Razafimaharo
Hi @Anonymous,
Here are some more options:
Crossing my fingers!
Hi Julia,
thank you for ideas...
Pff...I think I will burn this computer.
Franck R.
Hi Julia,
I tried : ping 23.212.255.218...it works.
But installation still does not 😞
Good night!
Franck R.
Hi @Anonymous,
Let's have a closer look at your proxy settings, since this is in your logs:
Follow these steps and let me know what you see:
Hi Julia,
I'm like a hen in front of a knife (french expression)...
It works! You were right : a proxy connection was activated.
At the beginning I just had a look on my internet browser, I think.
Thank you so much for your help.
I'll tell you when the installation will be finished.
If you have a postal adress, I'll send you chocolate and cheese from Savoie (France)!
Best regards.
Franck Razafimaharo
Bonjour, pour votre information, nous avons un forum en français à Fusion 360 - Français - Autodesk Community
I have the same problem, the same error appeared and i have not found a solution, please help me. 😞
