Hello, I have a problem, as said in the title I am forced to launch Fusion 360 with administrator privileges. When I double click on the icon it does not open but when I right click then "execute with administrator privileges", the software opens and works very well.
Thank you in advance for the answers.
Solved by jhackney1972. Go to Solution.
If you log into your computer as the administrator and then manage the Windows account you want to use, you can give them enough rights to run Fusion 360. This probably is the easiest method of fixing this issue. I am also assuming that you installed Fusion 360 as an administrator to make sure it had proper access to all the required folders.
John Hackney, Retired
