Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Guide Rail Lofting issues
2 REPLIES 2
Geboy37
900 Views, 2 Replies
 So now that I got the lofting somewhat figured out, I am trying to get my guide rails to work. In the first pic you can see the highlighted sketches that I am lofting between, and the upper straight line, and lower spline curve are my rails. I have tried multiple times to get them coincident, and it appears that I succeeded, but when I try to attempt the loft with the rails, I get the error that my rail does not connect all profiles. So when I zoom in (other pic) you can see that they are not connected, but have the coincident mark on them. I can even measure the distance between them, usually comes out to be .005-.006mm which might be the tolerance of this program...Idk.
Then other thing is when i made my spline curve, I finally got it to intersect all sketches and when I went into loft to see if it worked, it did indeed work. So I said, ok now I will try an fix the upper straight rail. Well after re drawing the upper straight rail and making it coincident to my sketches, a section of my lower spline curve totally vanished... and I had to re draw my spline curve all over again. And this time it was much more difficult to get the spline coincident with the sketches. Is it a bug???
2 REPLIES 2
jhackney1972
in reply to: Geboy37
I would like to suggest a method of creating rail connection points between your loft section sketches that I find makes the job a lot easier.  Take a look at my screencast.  I of course did not have your model so I just created something to demonstrate on.  I also only created connection points on one plane between the loft sections for time sake but you could use as many planes as you would like.  I used origin planes but your could create your own planes as well.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Geboy37
in reply to: jhackney1972
Thank you, thank you, thank you! That should make things a lot easier! Let me give it a whirl...
