OS Name: Microsoft Windows 10 Pro
OS Version: 10.0.19030 N/A Build 19030
Attempt to start program, it will freeze and never get to the splash screen. I'm available to grab whatever info you need from the process, since it doesn't die. It's just hanging.
Same here. I've taken a look at the logs, and there are some strange "file not found" errors for files that are clearly there.
Things I've tried:
- uninstall then running the clean uninstaller tool, then re-installing (note, after the installer finishes it's work, the subsequent launch of fusion360 so you can sign in never happens... although there is a background process for both f360 and the launcher that stay in the background without crashing basically forever.)
- added fusion360, and the fusionLauncher.exe (from both production and meta directories) to the list of apps to allow firewall access, making sure both public and private networks were allowed
- logging on to my other windows machine got a popup that said there was a session open on the first machine. I chose to force that sessions to close, went back and tried to launch, still no bueno...
- running in both windows 8 and windows 7 compatibility mode
- forcing the program to run as admin (note... when you configure it this way, the missing file error actually gets displayed, whereas normally it's just burried in the logs and no popups or anything show)
- changing the graphics driver to use the onboard display
None of this works. I've attached my complete `autodesk.webdeploy.streamer.log` from one of the fresh install and launch attempts.
Edit: rolling back didn't work for me either
Probably exactly the same problem is described here:
https://forums.autodesk.com/t5/fusion-360-support/fusion-360-will-not-open/td-p/9164622 and here:
...maybe it can be merged into one topic.
I did the very same without any luck. Fusion seems to start and it is visible in the task manager as a background task without any screen interaction.
same issue with Win10 19030
i can see it in task manager and that's all
I've uninstall it and reinstall, same issue
I have the same issue but didn't see this thread until I'd posted.
I've tried all the recommended fixes, (auto clean + reinstall, manual clean + reinstall, check proxy, check antivirus, check firewall) and it never even creates the folders for the application logs although it's can be seen to have started up in Task Manager.
was going mad i think, exact same problem with build 19030, tried everything, shows up in task manager, but that's all..
Also on Windows 10 build 19033.1, Meshmixer starts with a popup titled "Meshmixer Update" saying "Cannot connect to the server. Please check your internet connect". As far as I can tell, my internet connection is fine. Adding Meshmixer tp the Windows Firewall list of allowed apps has no effect.
I rolled back my OS to 19025.1052 on my laptop and desktop and Fusion started on both...I had a project I had to finish and it seemed to be the only way to get it to work.
