Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Education license expired issue and what you can do about it
82 REPLIES 82
Message 1 of 83
keqingsong
6347 Views, 82 Replies
We are hearing reports from some of you experiencing unexpected license expiration issues. If you were presented with a dialog telling you that your license has expired and that you have to renew into to continue using the software. This issues is affecting those of you with legacy 3-year education licenses. We are actively working on investigating this issue and apologize for the inconvenience.
If you are experiencing this issue, please reply to this thread and attached your diagnostic log file to your response. Your help here is greatly appreciated and will help us accelerate our investigation so that we can resolve this issue ASAP.
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
82 REPLIES 82
Message 2 of 83
opus1
in reply to: keqingsong
Hello, I had the problem. As I urgently needed my documents, your technical department told me that the only solution was to take out a paid subscription. 😞
Attached is my log file.
Thanks for your help.
Best Regards
Message 3 of 83
We have now resolved this issue. A restart of Fusion 360 should get you back to proper license. Please note that this impact and fix is for anyone experiencing this with an Education / student license.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 4 of 83
Bonjour
moi j'ai une licence personnelle non destinée à un usage commerciale et depuis 2 jours je rencontre un problème avec fusion je n'ai plus accès à mes données (pas de connexion au cloud) alors que ma licence est valable jusqu'en 2022.
j'ai désinstallé fusion puis j'ai réinstallé Fusion 360, rien n'y fait. le logiciel s'ouvre mais je ne peux que travailler hors ligne.
je vous joins mon fichier de diagnostic en espérant que vous puissiez trouver une solution
merci
Moderator note: adding English translation:
Hello
I have a personal license not intended for commercial use and since 2 days I have a problem with Fusion I can no longer access my data (no connection to the cloud) while my license is valid until 2022.
i uninstalled fusion then i reinstalled fusion 360, nothing happens. the software opens but i can only work offline.
I am attaching my diagnostic file and hope you can find a solution
thanks
Message 5 of 83
@tgudin Can you please try the below:
1. Can you login to https://accounts.autodesk.com/ without any issues? I am sure you will see your designs in here if you do.
2. The logs does show an error to connect to some of our services. Can you simply restart the machine and see if that helps? Many times that simply gets everything we need.
3. One another option would be to restart your router if you are connected to a wifi. Although this helps for some other errors it would certainly be worthwhile to try this.
If none of this helps we can look at other options.
Autodesk Fusion
Join Fusion Insider
Message 6 of 83
RajkumarIlanchelian
in reply to: opus1
@opus1 Did a restart of Fusion fix your issue? I see that you have a student entitlement and we did a fix that should take care of it.
Autodesk Fusion
Join Fusion Insider
Message 7 of 83
opus1
in reply to: RajkumarIlanchelian
No, restart soft and mac does not solve the problem.
I log in, but with my paid account, not educ one.
Can you tell me when my educ account stops?
Or where can I find it?
Message 8 of 83
RajkumarIlanchelian
in reply to: opus1
@opus1 We are checking internally on the state of your EDU license.
Autodesk Fusion
Join Fusion Insider
Message 9 of 83
@opus1 I checked with our license team and it looks like your education account is showing up as unverified account. Can you use this link - https://www.autodesk.com/education/edu-software/overview?sorting=featured&filters=individual and get started with Fusion 360 verification (Get started should take you into Individual or school/lab etc and walk you through the process). Once the account is verified then you should get the access.
Autodesk Fusion
Join Fusion Insider
Message 10 of 83
opus1
I've never been asked this before. I had a startup license, and one day I saw "education license" appear in my menu bar. Do I have to request a statup license again?
Message 11 of 83
RajkumarIlanchelian
in reply to: opus1
@opus1 You can apply for the one that you qualify. Are you still qualifying for an education? if not you will have to go the startup route.
Autodesk Fusion
Join Fusion Insider
Message 12 of 83
I have been accessed the student license for some years, and I am still a student in college now. But fusion 360 suddenly said my education license is expired now, and I can't find anyplace to renew or re-access my account. I saw post also talking about this problem. https://forums.autodesk.com/t5/fusion-360-support/please-help-for-the-renew-of-of-education-license/...  How can I fix it?
Message 13 of 83
RajkumarIlanchelian
@Anonymous Please use this link and you should be taken to a page where you can select Fusion 360 and then if this is individual or class/lab etc and you should be guided to the verification process.
Autodesk Fusion
Join Fusion Insider
Message 14 of 83
moderator note: English translation added:
I did what you said but it still doesn't work.
Here is attached a screenshot when I opened the merge and my diagnostic log
At the beginning, I had a student license that I had transformed into a personal license about 1 year ago.
thank you for your help
Sincerely
Mr. Gudin
Bonjour,
J'ai fait ce que vous avez dit mais cela ne fonctionne toujours pas.
voici en pièces jointes une capture d'écran à l'ouverture de fusion et mon journal diagnostic
Au début, j'avais une licence étudiant que j'avais transformé ensuite en licence personnelle il y a 1 an environ.
merci pour votra aide
cordialement
M. Gudin
Message 15 of 83
I couldn't find any place for me to input my student information. When I clicked in the Fusion 360 button, it just forced me to download the app over and over again, but my student account is still expired now.
Btw, I have been using Fusion 360 education license for around 4 years. I am still a student now. It just suddenly said my license is expired but don't tell me how to re-access after I update the app. I believe this is just a synchronizing bug.
Message 16 of 83
Message 17 of 83
RajkumarIlanchelian
@Anonymous I added a small word document that shows how you can go about verifying for the student license. The key is if you are having multiple accounts to use the account user Id of the student account. Please let me know if this helps.
Autodesk Fusion
Join Fusion Insider
Message 18 of 83
I couldn't have step 4 to 6 in your word file. When I clicked "access" fusion 360, it just took me to download Fusion 360. I tried this hundreds of time. I think maybe I have been using Fusion 360 for many years as a student, and it skipped the step 4 to 6. Can you help me to re-access my education license manually?
Message 19 of 83
RajkumarIlanchelian
@Anonymous I am reaching out internally to see what could be done. Will update you as soon as I have information.
Autodesk Fusion
Join Fusion Insider
Message 20 of 83
@tgudin As I mentioned your issue is not really the education license expiring. This is a different issue where you are forced to go offline. Can you try the below, please?
1. Logout of Fusion
2. Close Fusion
3. Go to C:\Users\YOUR USER ID\AppData\Local\Autodesk\Autodesk Fusion 360\UNIQUE NAMED FOLDER (like 200** or alphabets)/Delete OfflineCache.xml
4. Restart your machine (generally not needed but would recommend)
5. Now start Fusion 360 and login
I am hoping now you will be able to login and be online successfully.
Autodesk Fusion
Join Fusion Insider
