I have a design which reliably causes a crash-to-desktop on both Mac and Windows installations of Fusion due to what looks like a stack overflow when switching to the manufacture workspace. It crashes so hard the normal error-reporting framework doesn't fire, and I'm left with the "Report to Apple" stack dump (attached).
I've tried exporting an f3z archive and re-importing, which also triggers the crash.
Is there a way through the scripting API to delete the setups or entirely reset the CAM workspace? This particular file has several fixtures that I'm hoping to not to have to rebuild; the CAM operations would be straightforward to recreate from an earlier version of the design which does not crash.
Thank you.
