Fusion Support
[BUG] grounding is deleted when reorganizing assembly
3 REPLIES 3
TrippyLighting
838 Views, 3 Replies
I've got two simple components, a cube and a cylinder.
The cube is grounded and the cinder is joint to the top of it with a rigid joint.
then I create a new and empty component called Asm and rag the two other components into that assembly.
Fusion 360 deletes the grounding of the cube.
Peter
3 REPLIES 3
Logged as FUS-47954
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
This bug was fixed in June 2019 release.
Please let me know if you can still reproduce it. Thanks!
Rishabh Bisht
Product Owner
This is fixed. Thanks!
Peter
