archive or delete??
fredJME3H
archive or delete??
fredJME3H
Hello Chaps, I am a newcomer to Fusion so please forgive the newby questions.
On the left of my screen there is a panel with all my projects
My question is - if I delete a project is that the same as archiving the project?
If I delete the project does it also remove the files from my hard drive?
many thanks
Fred
g-andresen
If you have saved a design on the local system via export, you can delete this design.
The local version will be preserved.
Tip: Create a test folder once, save a design to it and export it to a local disk.
Then test the behavior.
günther
fredJME3H
thanks for this info gunther,
so in reality is all fusion work only on the cloud ? and the way to get it to a local disc is to export
from the cloud to the local disc.?
many thanks
fred
Type a product name
