Hello everybody
I've bought some tapered mill 2 flutes on for cutting some delrin using fusion 3D toolpath.
In the tool website description says:
-Flutes: 2 Flutes
-Coating: TiAIN
-Per Side Angle =5.09°
-Shank: 3.175mm
-Cutting Length: 15mm
-Overall Length: 40mm
-Tip Radius:0.25mm
Everything looks pretty straightforward expect that I not sure if the Tip Radius is referred to Corner radius setup parameter in Fusion or It's just half of the diameter so I need to put that in the fusion tool diameter (Radius x 2).
From the picture looks like it's referring to the Corner Radius parameter but then if it's so what the diameter of the tool will be? It doesn't say it
I'm in a bubble .
Thank you and sorry for my newbie question
