I modified a post processor from here:
https://forums.autodesk.com/t5/fusion-360-computer-aided/using-a-mill-as-a-lathe/td-p/6450214
You can download it in this thread below. I will also link from the video to this post so that it's nice little loop. 😄
With some code for coolant from the Haas mill post, I have tested this successfully. The key is put a comment "G54" or "G55" or whatever WCS in the tool comment in Fusion. My modified post will look for those terms "G54,G55,G56, etc, etc" and change the WCS anytime a tool is changed in the CAM in Fusion.
My video explains how the post works in much greater detail here:
https://youtu.be/DV5vXKBriDY
This is what my tool block looks like:
Solved by seth.madore. Go to Solution.
That's some serious outside-the-box thinking, kudos to you! I'm bookmarking this post so I have something to point to next time someone asks about turning their mill into a lathe. Thank you for sharing!
Thank you. It has worked very very well for me. Super rigid and makes very nice surface finishes in SS 304.
Have you tried this post recently with all of the Fusion updates? I am interested in using it but was curios if you were actively using it. Thank you for making it!
