Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
[BUG] Regenerating all tool paths causes crash
7 REPLIES 7
Message 1 of 8
andrewbarton
720 Views, 7 Replies
Here is a reproducible bug which crashes Fusion when regenerating all the tool paths.
The interesting thing is if I regenerate each tool path separately it's fine!
Then, if I regenerate all tool paths again it will crash.
I know the penultimate tool path needs fixing but this is where I got to...
I'm running on Mac OS X 10.12.6
File attached
7 REPLIES 7
Message 2 of 8
jeff.pek
in reply to: andrewbarton
That sounds kind of similar to a problem we've seen in another report -- though that one wasn't a crash.
Was there a crash report submitted? Are you able to share the model that's triggering this?
Jeff
Message 3 of 8
jeff.pek
in reply to: jeff.pek
Sorry, I see you already attached the model. Thank you.
Message 4 of 8
andrewbarton
Yes - I sent in several crash reports!!
Message 5 of 8
jeff.pek
Good. Thanks. Can you tell me which e-mail you would have used for those reports?
  Jeff
Message 6 of 8
andrewbarton
Hi Jeff,
I've just sent it as a PM 🙂
By the way, I tidied the penultimate tool path to get what I needed and it still fails.
Many thanks for looking at this,
Andrew
Message 7 of 8
andrewbarton
I've disabled each tool path one-by-one and the offender is the 4th in the list - the 3D Contour with Tool 21.
Disable or suppress this tool path and everything is fine; enabled it causes a crash but only if all tool paths are regenerated - on its own, it's fine!!
Message 8 of 8
jeff.pek
Thanks for the extra info. I can reproduce this issue on my Mac as well.
It seems kind of related to the other issue I mentioned above, but with different symptoms.
We've raised this as ticket CAM-18365, and our dev team is investigating.
Thank you for the report. Apologies for the inconvenience.
Jeff
