[BUG] Regenerating all tool paths causes crash
andrewbarton
andrewbarton
Here is a reproducible bug which crashes Fusion when regenerating all the tool paths.
The interesting thing is if I regenerate each tool path separately it's fine!
Then, if I regenerate all tool paths again it will crash.
I know the penultimate tool path needs fixing but this is where I got to...
I'm running on Mac OS X 10.12.6
File attached
Replies (7)
jeff.pek
That sounds kind of similar to a problem we've seen in another report -- though that one wasn't a crash.
Was there a crash report submitted? Are you able to share the model that's triggering this?
Jeff
jeff.pek
Sorry, I see you already attached the model. Thank you.
andrewbarton
Yes - I sent in several crash reports!!
jeff.pek
Good. Thanks. Can you tell me which e-mail you would have used for those reports?
  Jeff
andrewbarton
Hi Jeff,
I've just sent it as a PM 🙂
By the way, I tidied the penultimate tool path to get what I needed and it still fails.
Many thanks for looking at this,
Andrew
andrewbarton
I've disabled each tool path one-by-one and the offender is the 4th in the list - the 3D Contour with Tool 21.
Disable or suppress this tool path and everything is fine; enabled it causes a crash but only if all tool paths are regenerated - on its own, it's fine!!
jeff.pek
Thanks for the extra info. I can reproduce this issue on my Mac as well.
It seems kind of related to the other issue I mentioned above, but with different symptoms.
We've raised this as ticket CAM-18365, and our dev team is investigating.
Thank you for the report. Apologies for the inconvenience.
Jeff
