Announcements
How to set effectivity date with scripting
philipfrench
philipfrench
On the Managed Items tab, I want to set the lifecycle and effectivity date.
I can set the lifecycle using
item.workflowItems[i].lifecycle = 'Production'
But please how to read/write the effectivity date in javascript?
sven.dickmans
You can pass a java date object to property effectivityDate ... the following code will set the effectivity date to today:
    for(var i = 0; i < item.workflowItems.length; i++) {
        var workflowItem = item.workflowItems[i];
        workflowItem.effectivityDate = new Date();
 See the Methods on Workflow Items array in the online documentation within : https://help.autodesk.com/view/PLM/ENU/?guid=DEV-SCRIPT-REF#item-workflow-items-array
philipfrench
Thanks Sven.
I actually tried this again this morning before your post.
There was enhancement added in April 2024 to allow this property to be set by scripting. Thanks Autodesk dev!
If anyone wants to try Sven's (correct) example, there are two problems you may encounter:
  1. "EffectivityDate for workflow item 2246955 is not editable". Go to Lifecycle Manager, right-click the eg Released box, and ensure that 'effectivity' checkbox is selected.
  2. "Cannot set past date 2024-xx-xx as effectivity date" - you may have forgotten that month in javascript's Date(yyyy, mm, dd) constructor is zero-based, so 0=Jan, 1=Feb...
Respectfully, to the other poster, please stop this run of posting AI generated nonsense.
We can all paste questions into Co-pilot. You are copying rubbish that doesn't even answer the question, and code examples that wouldn't anyway work.
