Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Problem importing DXF: dimensions not matching
2 REPLIES 2
376 Views, 2 Replies
I want to create an electronic component from sketch. From this question ( https://forums.autodesk.com/t5/fusion-360-electronics/create-electronic-component-from-sketch/m-p/10... ) it was suggested I export as DXF.
ISSUE
However I am having troubles with importing the correct dimensions.
I've used the following procedure:
EXPORTING AS DXF
With the 1) Units set to mm and 2) dimension around 47mm,  I did 3) File -> Export -> typeDXF
NEW ELECTRONIC LIBRARY
The I created a new electronic library and footprint:
  • File- >  New electronic Library -> save.
  • Create new footprint ->  save
IMPORTING DXF
In command line: Run -> import-dxf
Then I have imported with settings to inches
And settings to mm:
Both times I get the WRONG MEASUREMENTS
I've attached the dxf file
Labels (2)
2 REPLIES 2
edwin.robledo
Hi  leodavide.torchia2,
I hope all is going well.  I used your dxf to create a PCB outline, then I Group/Copied it to the library to fine-tune it.  Let me know if this works for you. I attached the library.ANT.png
Edwin Robledo
Tech Marketing Manager
Hi @edwin.robledo ,
Sorry, could you expand on your insturctions?
TRIAL FROM ELECTRONIC DESIGN
I've tried:
file -> new electronic design
run->import dfx
results in a misshaped connections.
TRIAL FORM UPLOAD DXF VIEW AS SKETCH
I also tried:
Upload file -> open  (whcih displays hte dxf as a sketch)
create-> 3DPCB (tried also the other)
But the result is a single block without traces visible.
CURRENT ISSUES
I am not sure how to:
1. Create a pcb OUTLINE FROM dxf
2. redimension the shape from library/footprint window
thanks,
Leo
Technology Administrators
