Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
how to ?
1 REPLY 1
adam68.moscicki
113 Views, 1 Reply
how to ?
I'm a begginer in 3d ...need help how to ? ..
I have a roller shape body ( circle 30mm extruded up 10mm )  and I wont to make the upper plane not flat but "extrude" it to small sphere shape just 1 mm up.  how can I make this ?
thanks for help 🙂
Adam
Someone showed me a geometric solution but i ask if there is a function in Fusion 360 to make it easier ?
added graphics:
1 REPLY 1
kellings
in reply to: adam68.moscicki
An alternate way to make a feature like that would be to use the loft command. I made a short video to show how you would do that.
https://bit.ly/3ShUC9v
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
