Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
How to define an organic shape brought in as a svg (hand drawing)
3 REPLIES 3
patrick_william
129 Views, 3 Replies
I draw my shapes by hand ( I am a sculpture by trade). All my sketches are undefined as a result, ( which I think is causing trouble later. I do it right and start out with components and then bring in the SVG file ( but I am missing the ability to define the sketch because it is organic and not geometric that the sketch definitions seem to work off of.
I end up extruding them and skipping this part. But the sketches stay blue instead of a defined black.
Is there a trick to lock the sketch... I know there is a FIX/unFIX on the constraints, but the sketch in the browser still remains with the pencil icon which means it is not defined.   Any clue of how to do this?  Thank you
3 REPLIES 3
kellings
in reply to: patrick_william
Hi @patrick_william If you fix all the entities of a sketch, the sketch should show a lock on the sketch icon to let you know it is locked. I wonder if there is some part of your sketch somewhere that didn't get a fix constraint applied?
I did a quick test just to be sure. Here you can see I drew a line and then used the fix constraint on the entire line (start point, line, end point) and the lock shows up for the sketch.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
patrick_william
in reply to: kellings
thank you Kevin,
But that is a straight line. what do you for a spline type of line that an organic shape has?
kellings
Good morning @patrick_william. I just tried with a spline and got the same result of the locked sketch.
Do all of your sketch entities turn green when you use the fix constraint on them?
Kevin
Kevin Ellingson
You've got Fusion.
