Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
assembly lines
3 REPLIES 3
bpesek0
110 Views, 3 Replies
assembly lines
Hello, I have assembled this frame out of a few parts and you can se lines where they have merged. As I need to make a drawing of this i need them gone. Can you help me?
3 REPLIES 3
kellings
in reply to: bpesek0
You have a couple of options here. A fairly automatic way would be to use the combine command to subtract away portions of the overlap that you don't want. Make sure you check the box to keep tools when in the combine command.
You could also manually draw and extrude the areas away that need to cut.
If you need some help, post your file here and I can edit it to show you how it would work.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
kellings
Hi @bpesek0 were you able to make any progress with this one?
Kevin
Kevin Ellingson
bpesek0
in reply to: kellings
Hello, yes I got rid of the lines with the combine command.
Thank you!
You've got Fusion.
