Look at the displacement of the motor after breaking the link of the component.
Solved by innovatenate. Go to Solution.
I'm wondering if the below conversation may also apply here as well.
I hope that helps! Please let me know if you have any questions. If the above discussion does not help, can you share the design with me for a closer look?
Hi Nathan,
The motor is grounded and rigid but the behavior is the same.
Here my designs:
Motor -> http://a360.co/2eXjSmy
4-Axis -> http://a360.co/2dZhCwi
Thanks for sharing those. I'm currently stumped by this one.
I note if you edit RigidJoint 6 there are some missing references errors that I haven't been able to wrap my head around.
I've gone ahead and logged this issue with development reference ID FUS-28672. As soon as I learn more, I'll be sure to circle back here.
Have a great weekend!
@macmanpb I have an update for you on this issue. The issue has been tracked down to a complication mirror component feature and, distributed design. We are targeting a December fix; however, it is still pending validation and approval. Thank you for reporting this issue to us and helping us track this down!
Good news! The fix is scheduled to be released in our up-coming Jan update!
