"Components out of date" Message error?
Various times throught the day, on many different files, I get a warning that tells me two components are out of date. But any files I am working on are not out of date (and the message appears even on files that do not have linked components).
I have attached a screenshot showing the message I recieved today and you can see the component is not out of date and in fact there aren't two components linked, or other files open.
What is this message talking about? Is it possible to see what file it is referring to?
Thanks!
Replies (49)
And here I am again, being annoying (sorry Smiley Embarassed).
We have a few other users here in house, and it turns out, one of them are seeing the same behavior - the same message, etc. On files he creates as well. (these are in the "general drawings" folder, I do the work in the "Fabricated cases" side, and we both end up in "standard products" and "customer drawings".
I've asked him to pass on screenshots/screencasts of when it occurs for him as well. We are both working to reproduce it now.
ahsan.autodesk
Appreciate your posts. Good to work with such responsive users.
I'm not sure the reinstall could've changed any behavior. It should definitely not have made the messages appear more frequently. Anyways, I'm adding code to shut these messages in the CAM workspace for sure. That change won't be part of the upcoming early-May update though. That train has already left the station ... I hope to catch the next release train after that.
Ahsan
Ahsan Ali
Fusion Senior Software Architect
Okay, good to hear Smiley Happy
When you get a date, let me know please, and I'll keep an eye out for the messages after that update.
Thanks for all the help!
ahsan.autodesk
Hi there,
The team believes we've checked in the necessary changes to block the out-of-date messages to appear in the CAM workspace. Please let us know if you continue to see them after the update (which will come out hopefully in the third week of this month).
Thx and regards,
Ahsan
Ahsan Ali
Hi @ahsan.autodesk
I was just thinking about this - because I haven't seen it since the last update. Neither has my coworker.
So, I'll be sure to follow back up if it does happen.
Thanks!
Hello @ahsan.autodesk
Perhaps it's a bit late but I've figured out how to reproduce it! Yay! Smiley LOL The steps to reproduce work on my coworkers computer as well. It is currently still occuring on both of our computers (Macs).
Start with two files - Original File and CAM file let's call them.
Insert Original file into CAM file.
While in the CAM workspace of CAM file, open Original File.
Update Original File.
Go back to CAM file (still in CAM workspace) and open the Data Panel (do not update out of date references).
Right click on CAM file in Data Panel (still not updated!) and choose "Share Link".
The "out of date" message then appears in the CAM workspace! Smiley Happy And it keeps appearing in the CAM space of any file until I quit Fusion.
Then, it lays in wait until I share an out of date file while in the CAM space again.
I share files often - between coworkers and customers - so this is a semi-regular occurance - opening a CAM file that may not be updated and sharing it. I've been getting better about keeping things updated so I've been seeing it less. That's why I noticed right away today when it showed up when I was sharing a file.
Here's a screencast too! Smiley Very Happy I'm kind of excited I managed to figure it out.
Thanks for your assistance!
ahsan.autodesk
Yippee!! This is great news indeed. I'll try to reproduce it locally, and then hopefully, we can truly fix it.
Thx for your help @Anonymous
Ahsan
Ahsan Ali
ahsan.autodesk
Hi @Anonymous,
Just wanted to mention that I was able to reproduce the problem using the steps that you mentioned!! We'll investigate the reason soon.
Thx again for your help
Ahsan
Ahsan Ali
ahsan.autodesk
Created internal issue UP-28596 for tracking purposes
Ahsan Ali
@ahsan.autodesk
Excellent! Smiley Very Happy
Thanks for you help!
