- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Fusion has a demo script OpenFileFromWeb that does exactly what it says. If you find the script's folder on your hard drive there's an html file that allows you to open\insert files directly into Fusion. If you copy the html file to a directory that doesn't change when Fusion updates you can open the file in Chrome and run any time. I'll put a version of the file in the next post in this thread you can test. If you paste the link below into the imput field in the post below and click Open in Fusion the file is opened without going through the trouble of manually downloading.
https://forums.autodesk.com/autodesk/attachments/autodesk/453/1012/1/temp.f3d
If you want to open\insert files from your hard drive you need to paste the full path and file name.
Mark
Mark Hughes
Owner, Hughes Tooling
