My Fusion 360 models turn black....
Lifeisriding
Lifeisriding
My models turn balc after working on them for a random amount of time.
THis was a major problem when I started using Fusion and seemed to have gone away in the past month or so but no is back. Does anyone  else have this issue? Is there a solution?
I just restart the program so that I can keep working but doing that all the time is a major pain in the ****.
Here is a screen shot so you can see what I am talking about if you don't already know.
Replies (8)
innovatenate
Autodesk Support
Autodesk Support
Thanks for posting about this issue and welcome to the Fusion 360 community. Historically this issue is related to graphics. Can you tell us more abou the operating system, and video card you are working with? If you are on Windows, when is the last time you updated the graphics driver for your video card?
You may try the suggestions in the below URL's to see if they can helpl with this issue.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
and..
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Poo...
I hope this helps!
Nathan Chandler
Principal Specialist
Lifeisriding
Hello Nathan!
Thanks for the quick reply. I am loving Fusion 360 otherwise so far! I see why people are called evangelists, I have been converting many of my engineer friends over from solidworks.
I am running it on a 2012 Macbook.
10 Gigs of Ram,
250 Solid State HD
Intel HD Graphics 4000 1536 MB
I don't seem to have any "slowness' or lagging problems.
Even when the modle turns completely back I can still orbit around , click on parts of it and zoom in with out issues.
Just all the surfaces and sketchs go compleltely black so you can't really see what you are doing.
I have googled around about it and haven't seen anyone else referenceing the model going black so far.
ChristophUnbescheidt
Hello !
sometimes i got the same problem with my iMac 5k 4gb gpu...
So it can not be a graphic card issue.
My advice is to cahnge between MODEL and RENDER mode and it mostly dissapears 🙂
Hope that hepls!
Industrial Designer
c.unbescheidt@gmail.com
Lifeisriding
Thanks for the sugestion Christopher.
Unfortunetly switching the desktop modes doesn't seem to make a difference. The model stays black acrross all the different work spaces.
chengyun.yang
I suppose you are not running a Windows OS on your Mac machine, right? If you are not, then one possible reason I can think of is some temporary shader/texture files used by the rendering are deleted somehow on your machine, probably some regular system disk clean up tool. A couple of questions:
1. Did you see this problem after you put the machine in the sleep mode for a while and then wake it up again?
2. When this issue happens, you can simply fix it by restarting Fusion. Is it correct?
Chengyun
Same problem here.
Windows 10 64bit
8gb Ram
Intel 4000
Intel i5
Just switch between differnt Modes llike render and model... if that doesnt help go to preferences, gaphics, and switch to better performance 😉
Industrial Designer
Is this surface a patch surface? If it is you can go to patch mode and swicth normal and see if something changes 😉
Industrial Designer
