Insert Custom View in Drawing
Hi all,
I want to insert view in drawing, but model is 40° rotated to front plane. When i try to insert in drawing as a front view, it is taking oriented view. I need basic front view to be inserted.
Replies (18)
mishrani
Hi @Anonymous,
You can use NamedView to get the orientation you want -
1. In the design, use "Look At" (available in the bottom navigation bar) then select the face you want to see in your view.  You'll now be looking at that face head on.
2. Create a new named view of that orientation (Right-click Named Views in the browser)
3. Now when you create a drawing and place the base view, select the corresponding named view as the Orientation in the Drawing View dialog.
Dear Mishrani,
Thanks for your support and quick response..!!!
HughesTooling
Just want to add if you can't orientate the view correctly add a joint origin and select when you use Look At.
Here you can see the document origin isn't aligned with the base of the triangular face but adding a joint origin and selecting with look at aligns the part.
Mark
Mark Hughes
Owner, Hughes Tooling
ELAFING
I needed this tonight. Just want to say thank you.
I created a "named view" per your instructions. Saved the file. Created a drawing but when I placed a base view the new named view was not on the list!
Help
HughesTooling
@Anonymous  Can you make a screencast of what you're doing? I just did a test and it worked correctly for me.
Mark
Mark Hughes
Good day Mark,
Thank you for replying. The missing step was to hit refresh in the drawing
and then the new view was there.
Carl
Hi all...
Reviving an old thread here but I can't post a new one without it being marked as spam... Similar issue as op, need a custom view of an angled part but I can't make it happen when generated from an assembly... Works fine when generating drawing directly from the part. Any help greatly appreciated
Save a screen capture as a .jpg, or equal, picture file the insert the
picture in the drawing. No the most elegant solution but when all else fails
this can get the job done.
Carl
Thanks for the reply. Unfortunately a jpg wont work as I need to import the drawing file into other software and need to pick up the geometry....
DokteurP
markaudacity
Necroposting because yours is the only answer I've found to this problem, but this no longer seems to work; Look At will not allow me to select a joint origin, either attached to a sketch object or to an extrusion from it. 😕
[EDIT: apparently you have to select the join origin first, then click Look At.]
gbeaudryHG2AS
THANK YOU!!!
Imprenta3D
Thanks, very hepful.
HughesTooling
Unfortunately my workaround from post #4 using a joint origin to align Look At no longer works.😠 I think when the gave us the new pretty joint origin they broke this feature.
Below I've selected the joint origin, clicked Look At but the view does not aligned to the joint origin's X and Y.
Mark Hughes
mango.freund
HughesTooling
Mark Hughes
jhackney1972
If I understand your old Joint Origin / Look At command trick, I believe you can now accomplish the same process by placing the Joint Origin on your component and then use the Align command with it and the Origin point in the Browser.  From that you can capture the Named View.
John Hackney, Retired
