If you were working Offline during the Fusion 360 maintenance window that occurred on Saturday May 7, 2016 (Sunday May 8, 2016 in some locales) and your work involved one of the following scenarios this is applicable to you.
1. You Created new designs by inserting other design(s) into it (external references) and saved it.
2. You Edited an existing design that contained links to other designs (external references) and saved it.
In either of these situations, once you updated to the latest version of Fusion 360, the links (external references) in the design that is using them may be broken. This might not be apparent if you are opening the design on the SAME COMPUTER where you were working offline. You can confirm if you are impacted by clicking on "Open A360 details" where you will not see the data in the viewer. If the design (that is using the external references) is opened on a different computer, you could see errors.
ACTION THAT WE STRONGLY ENCOURAGE YOU TAKE:
1. Launch Fusion 360 on the SAME COMPUTER (this is very important) where you created or edited the design that contains external references. Verify that you are online and have good connectivity.
2. Click on Help > About and verify that the Build Number is 2.0.2013 (it would be 2.0.2012 if you installed from the Mac App Store)
3. Open the design that contains the external references. The design should Open with all the external references intact.
4. Make a small change and Save the design (that contains the external references) again. Note: there is no need to save each of the external references separately.
If after reading this you feel this situation is applicable to you please DO NOT attempt an uninstall and reinstall. If you are unsure or still have issues after following the above steps, please post on the forum in response to this message and we will work with you.
We sincerely apologize for this issue and appreciate your patience in working with us.
best regards,
Sanjay Jayabal
(On behalf of the Fusion 360 Team).
