Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Drawing doesn't work. give me a help
6 REPLIES 6
kimdw356
414 Views, 6 Replies
When I trying to sketch drawing
The drawing screen does not appear,
the FUSION 360 only works by clicking and dragging.
Even other action buttons don't work
enable to click and drag
other button can click  but doesn't working
Please give me answer..
I attached the video because it wasn't enough as a picture
Tags (1)
6 REPLIES 6
Drewpan
in reply to: kimdw356
In order to draw a Sketch you first need to select the Plane you will draw on like this:
This will activate the Sketch Tools on the Toolbar here:
You should then be able to Sketch.
I would strongly recommend that you do the Basic Drawing Tutorials and check out the AutoDesk Tutorials
for Fusion 360. Then have a look at @TheCADWhisperer Tutorials on YouTube.
Hope this helps.
Andrew
Warmingup1953
I think I understand your problem. For design in Fusion 360 use the Modeling Environment(s). Once you have progressed with your design and you wish to document and communicate your work or WIP then you can move to the Drawing Environment. It is important to know that a sketch is not a drawing and a drawing is not a sketch. These terms, though similar in the wider world, have very distinct and different meanings in Fusion 360.
g-andresen
drawings are created from your design
günther
yoavweiss1
I have been having the same problem for few month now.
it used to work and then just stopped..
re installed, uninstalled other programs, antivirus etc.. for two month now, I've been messing up my pc..
long story short..
when trying to create a drawing, in task manager opens a new task "AcCoreConsole"
than the program stuck.
when in task manager ending the "Ac...", the program works..
I went to file location and tryed to "run as administrator" and it said "msvcp140_codecvt_ids.dll cant be found"...
google...
and then on some ADOBE forum I found the answer:
https://community.adobe.com/t5/download-install-discussions/problem-regarding-msvcp140-codecvt-ids-d...
and this the one that helped me.
https://learn.microsoft.com/en-US/cpp/windows/latest-supported-vc-redist?view=msvc-170#visual-studio...
marat150977
@yoavweiss1Thank you wery much for your help. I already can resolving this problem.
Technology Administrators
