& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Hello.
I do get why I should activate components but I ran into a situation which makes me climb the walls of my apartment.
While designing a plastic rig for a cellphone the design process went on just fine, for several hours during which time I added 2 already made and saved components.
Then a couple of hours of designing onwards I thought I was adding another component but as it turned out I right-clicked and chose "add to current design" on another parametric model.
I don't see why that should be a problem, but in the end I had added both a parametric model and a component but inside another component where I didn't want them so I deleted them and chose the top component or whatever it i called, the tab you activate to concern the hole file system for that design.
Now comes the weird stuff, now I can't activate any components anymore, the activation button doesn't appear at all, if I create a new component I can have that activate in it's creation but I can not activate any of the other 5 components.
I am very confused and don't know what is going on.
at some point I undid all steps I had taken before I aded the parametric model and then it seems to work again but even when I do it as I wanted and added a component to the root of the design the same thing happens so now I can't continue working on any of the components.
Does any one knows what is going on?
I can't solve this, I've been trying to do so for the last 3 hours and now I wish I was very rich so that I could afford to bash my laptop with a baseball bat until it was in dozens of peaces.
Seriously wouldn't it be wonderful if you could solve your frustration that way when software's are messing with you.
Attach your model and maybe make a screencast of your problem.
Hi @davidCWLJV,
More than likely, the components you cannot activate are externally referenced components. Those cannot be activated. Look for the little "chain" icon in the component. Only locally-defined components can be activated. This is because component activation determines where new objects like sketches or work geometry goes, and so is inherently a write operation. Today, Fusion does not allow you to edit external components, other than by opening them in a new tab of their own.
Here is a small screencast showing that local components can be activated, while external ones cannot.
And, as @TMC.Engineering says, if you share a screencast or the model itself, it will be much easier to help you.
Jeff
Based on your description my guess would be that you picked up a tool and bypassed the instructions that go with it.
One of the most important concepts of Fusion 360 is the difference between a component and a body.
Once you're through that, you should review Fusion 360 R.U.L.E #1.
I studied the Fusion 360 component system and I could not solve the problem, it ended in the creation of a completely new design and this time I manage to create components and switch between them without any problem.
I then later when back to the design with which I had trouble just to see if now that I think I know how to work with components I maybe could understand what was wrong but it feels as if something very strange has happened to that project because I simply can't solve it.
It doesn't matter since I recreated the design but it was weird.
Thanks for your replies.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
