Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Share a python module between my scripts
10 REPLIES 10
Message 1 of 11
lionel.courgnaud
720 Views, 10 Replies
I'd like to share a homemade module (containing only functions) between all my scripts.
My script Fusion Folder looks like :
Scripts
    |_ myscript1
         |_ myscript1.py
    |_ myscript2
         |_ myscript2.py
It seems I can't store my custom mymodule.py @ the root of fusion scripts folder ("Scripts")
How could I do to import this module into each of my scripts without copying it into each folders ?
I looked for some paths where I could copy mymodule.py but I found nothing.
thanks for your precious help.
10 REPLIES 10
Message 2 of 11
You can use sys.path.append() at the begining of the code.
Message 3 of 11
Thanks for the answer.
I tried :
import sys
sys.path.append('../mymodulepath')
Is there something else to do to have the autocompletion and/or import mymodule.py
It seems I can extend the sys.path but I don't know how to use it.
I found a system solution, but I'm not sure it's a good practice :
I created a symlink in my script folder. This symlink is pointing to mymodule.py
in my main script I added  from . import mymodule
now, I can access to mymodule.myfunction()
thés
Message 4 of 11
One solution I found is to create a symlink for the module (but it's not a real good python practice)
Exemple :
Scripts
|_ myscript1
|_ myscript1.py
|_ myscript2
|_ myscript2.py
|_sharedmodule
|_sharedmodule.py
Symlink in myscript1/ => ln -s ./sharedmodule/sharedmodule.py sharedmodule.py
Add to file myscript1.py => from . import sharedmodule
Call in this file sharedmodule.myfunction()
I noticed I had to restart visual studio code from Fusion360 to make it works.
Message 5 of 11
@lionel.courgnaud wrote:
import sys
Try this:
import sys
import mymodule
Message 6 of 11
JeromeBriot
in reply to: JeromeBriot
You can also directly use relative import:
from ..mymodulepath import mymodule
Message 7 of 11
hello.
thanks for your help. I tried to import mymodule but the only result I had was
ImportError: attempted relative import beyond top-level package
Message 8 of 11
Another attempt:
sys.path.append(os.path.join(os.path.dirname(__file__), '..'))
from mymodulepath import mymodule
Or:
sys.path.append(os.path.join(os.path.dirname(__file__), '..', 'mymodulepath'))
import mymodule
Message 9 of 11
I tried with this 2 declarations, and I can run the script, but I have no autocompletion writing my scripts.
A symlink is the best (and ugly) way I found to share module.
Message 10 of 11
Open the settings.json file in the .vscode folder and add the following entry as an item in the "python.analysis.extraPaths" list:
"${workspaceFolder}/../modules"
Watch this video:
Message 11 of 11
This solution is perfect for me 🙂 Thanks !
