I want to use TemporaryBRepManager.createBox in Parametric mode
kandennti
kandennti
Hello.
I want to create a box using TemporaryBRepManager in the baseFeature of Parametric mode, but I get an error at the time of bodies.add.
#Fusion360API Python script
import adsk.core, adsk.fusion, traceback
_app = None
_ui = None
def run(context):
    try:
        global _app, _ui
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        _app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        des  :adsk.fusion.Design = _app.activeProduct
        des.designType = adsk.fusion.DesignTypes.ParametricDesignType
        # des.designType = adsk.fusion.DesignTypes.DirectDesignType
        root :adsk.fusion.Component = des.rootComponent
        baseFeatures = root.features.baseFeatures
        baseFeature = baseFeatures.add()
        baseFeature.startEdit()
        tmpMgr = adsk.fusion.TemporaryBRepManager.get()
        box3D = adsk.core.OrientedBoundingBox3D
        pnt3D = adsk.core.Point3D
        vec3D = adsk.core.Vector3D
        box = box3D.create(
            pnt3D.create(1.0, 2.0, 3.0),
            vec3D.create(1.0, 0.0, 0.0),
            vec3D.create(0.0, 1.0, 0.0),
            3.0, 4.0, 5.0
        brepBox = tmpMgr.createBox(box)
        baseFeature.bodies.add(brepBox)
        # root.bRepBodies.add(brepBox)
        baseFeature.finishEdit()
        _ui.messageBox('Done')
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
In Direct mode, processing can be performed without errors.Is there a way to process in parametric mode?
Thanks in advance.
goyals
@kandennti Sharing an article on Temporary BRep manager by Brian Ekins
https://ekinssolutions.com/using-temporary-b-rep-in-fusion-360/
Shyam Goyal
Sr. Software Dev. Manager
kandennti
Thank you @goyals .
The second parameter was missing.
        # baseFeature.bodies.add(brepBox)
        root.bRepBodies.add(brepBox, baseFeature)
