Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to use the mesh repair comand in the API
1 REPLY 1
joao.araujoDNTFK
274 Views, 1 Reply
I need to use the mesh repair feature in the API and change the repair type (Wrap, Stich and remove, rebuild); is there anyway to do it?
1 REPLY 1
Hi @joao.araujoDNTFK .
I don't think the mesh repair command is provided in the API, but I made a sample using a text command.
# Fusion360API Python script
import traceback
import adsk.core as core
def run(context):
    ui = core.UserInterface.cast(None)
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        msg: str = 'Select MeshBody'
        selFilter: str = 'MeshBodies'
        sel: core.Selection = selectEnt(msg, selFilter)
        if not sel:
            return
        exec_mesh_repair('Wrap')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def exec_mesh_repair(
    repairType: str):
    repairTypeDict = {
        'Close Holes': 'infoTypeSimple',
        'Stitch and Remove': 'infoTypeDefault',
        'Wrap': 'infoTypeExtended',
        'Rebuild': 'infoTypeMakeSolid',
    if not repairType in repairTypeDict.keys():
        return
    app.executeTextCommand(u'Commands.Start ParaMeshRepairCommand')
    app.executeTextCommand(u'Commands.SetString infoRepairType {}'.format(repairTypeDict[repairType]))
    app.executeTextCommand(u'NuCommands.CommitCmd')
def selectEnt(
        msg: str,
        filterStr: str) -> core.Selection:
    try:
        ui: core.UserInterface = app.userInterface
        sel = ui.selectEntity(msg, filterStr)
        return sel
    except:
        return None
For more information about text commands, please read here.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/use-textcommands/m-p/9645688
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/use-textcommands2/m-p/9937161
