Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
How to remove inner sketch lines from an intersection sketch?
4 REPLIES 4
1936 Views, 4 Replies
How can I be able to remove the inner sketch lines of an intersection sketch, such that I only have the outer edges in Python?
For example, I have an intersection of my Brep body below. The left hand side is the output of doing the intersection sketch, and the right hand side is what I want. I did the right hand side manually through Fusion 360 but I need to also do it in Python code.
So, does anyone have an idea?
4 REPLIES 4
kandennti
hi. jmperez6
Because it was an interesting theme, I challenged it.
I use temporary patch surfaces and projections.
Therefore, we will create a new sketch which is the outer circumference of the profile.
(Because there are not enough exception handling, it may cause an error.)
 It is only parametric mode.
import adsk.core, adsk.fusion, traceback
_ui = None
def run(context):
    try:
        global _ui
        app = adsk.core.Application.get()
        _ui  = app.userInterface
        prod = app.activeProduct
        #select Sketch
        filters = 'Sketches'
        sel = Sel('Select Sketch / ESC-Cancel', filters)
        if sel is None:
            return
        sel_skt = sel.entity
        refplane = sel_skt.referencePlane
        #component
        comp = prod.rootComponent
        if sel_skt.assemblyContext != None:
            comp = sel_skt.assemblyContext.component
        #patch
        profs = lst2objCollection(sel_skt.profiles)
        patches = comp.features.patchFeatures
        patchInput = patches.createInput(profs,
                        adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        tmp_patch = patches.add(patchInput)
        #project
        res_skt = comp.sketches.add(refplane)
        [res_skt.project(face) for face in tmp_patch.faces]
        #Sketch Remove Reference
        curves = res_skt.sketchCurves
        pros = ['sketchArcs',
                'sketchCircles',
                'sketchConicCurves',
                'sketchEllipses',
                'sketchEllipticalArcs',
                'sketchFittedSplines',
                'sketchFixedSplines',
                'sketchLines']
        for pro in pros:
            [remove_ref(c) for c in eval('curves.' + pro)]
        #Remove Temp Patch
        tmp_patch.deleteMe()
        _ui.messageBox('Done')
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def lst2objCollection(lst):
    ents = adsk.core.ObjectCollection.create()
    for ent in lst:
        ents.add(ent)
    return ents
def remove_ref(skt_crv):
    skt_crv.isReference = False
def Sel(msg, selFilter):
    global _ui
    try:
        return _ui.selectEntity(msg, selFilter)
    except:
        return None
metd01567
in reply to: kandennti
Doesn't a generic SketchCurve have a deleteMe method/isReference attribute?  could that be used to avoid the walk though known curve types?
kandennti
in reply to: metd01567
I'm sorry. Similar processing can be done here.
        [remove_ref(crv) for crv in res_skt.sketchCurves]
        #Remove Temp Patch
metd01567
Thanks, I've got a similar problem.
