How can I be able to remove the inner sketch lines of an intersection sketch, such that I only have the outer edges in Python?
For example, I have an intersection of my Brep body below. The left hand side is the output of doing the intersection sketch, and the right hand side is what I want. I did the right hand side manually through Fusion 360 but I need to also do it in Python code.
So, does anyone have an idea?
Solved by kandennti. Go to Solution.
hi. jmperez6
Because it was an interesting theme, I challenged it.
I use temporary patch surfaces and projections.
Therefore, we will create a new sketch which is the outer circumference of the profile.
(Because there are not enough exception handling, it may cause an error.)
It is only parametric mode.
import adsk.core, adsk.fusion, traceback _ui = None def run(context): try: global _ui app = adsk.core.Application.get() _ui = app.userInterface prod = app.activeProduct #select Sketch filters = 'Sketches' sel = Sel('Select Sketch / ESC-Cancel', filters) if sel is None: return sel_skt = sel.entity refplane = sel_skt.referencePlane #component comp = prod.rootComponent if sel_skt.assemblyContext != None: comp = sel_skt.assemblyContext.component #patch profs = lst2objCollection(sel_skt.profiles) patches = comp.features.patchFeatures patchInput = patches.createInput(profs, adsk.fusion.FeatureOperations.NewBodyFeatureOperation) tmp_patch = patches.add(patchInput) #project res_skt = comp.sketches.add(refplane) [res_skt.project(face) for face in tmp_patch.faces] #Sketch Remove Reference curves = res_skt.sketchCurves pros = ['sketchArcs', 'sketchCircles', 'sketchConicCurves', 'sketchEllipses', 'sketchEllipticalArcs', 'sketchFittedSplines', 'sketchFixedSplines', 'sketchLines'] for pro in pros: [remove_ref(c) for c in eval('curves.' + pro)] #Remove Temp Patch tmp_patch.deleteMe() _ui.messageBox('Done') except: if _ui: _ui.messageBox('Failed:\n{}'.format(traceback.format_exc())) def lst2objCollection(lst): ents = adsk.core.ObjectCollection.create() for ent in lst: ents.add(ent) return ents def remove_ref(skt_crv): skt_crv.isReference = False def Sel(msg, selFilter): global _ui try: return _ui.selectEntity(msg, selFilter) except: return None
Doesn't a generic SketchCurve have a deleteMe method/isReference attribute? could that be used to avoid the walk though known curve types?
I'm sorry. Similar processing can be done here.
・・・ #Sketch Remove Reference [remove_ref(crv) for crv in res_skt.sketchCurves] #Remove Temp Patch tmp_patch.deleteMe() ・・・
