Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
[CRASH] - component.flatPattern.bendLinesBody on component with no bends
6 REPLIES 6
gvisca44
415 Views, 6 Replies
Was in the process of writing add-in that processes sheet metal components.
Found that component.flatPattern.bendLinesBody and component.flatPattern.extentLinesBody against a component with no bends causes crash.  Seems like component.flatPattern.bodies also causes a crash.
Crash report 336849264 sent.
Glenn.
6 REPLIES 6
BrianEkins
in reply to: gvisca44
A crash is never good, and even when you do something wrong, the API should fail and never crash. However, I created a very simple test case where I made a new design that contained a sheet metal part, inserted it into a new design, and then used the API to call the bendLinesBody property. I'm not seeing a crash, and it returns the body, so there must be something else that's causing it to crash. Can you post a test case and the code that reproduces the crash?
Brian Ekins
gvisca44
Will do @BrianEkins.
Just to be clear - because I mis-interpreted the symptoms initially.
The crash appears on sheet metal components that dont have bends (where initially I thought it was on linked components).  Just happened that my original tests included linked components that didnt have bends.
gvisca44
@BrianEkins
As requested.  The embedded image (which I have also included as attachment just in case) shows the progression of the script to the point of crash.
import adsk.core
import adsk.fusion
import traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        if not design:
            ui.messageBox('No active Fusion design', 'No Design')
            return
        allComps: adsk.fusion.Components = design.allComponents
        for component in allComps:
            for body in component.bRepBodies:
                if body.isSheetMetal:
                    msg = f'Component \t "{component.name}" has sheet metal body'
                    app.log(msg)
                    adsk.doEvents()
                    bendLinesBody = component.flatPattern.bendLinesBody
                    for BRepEdge in bendLinesBody.edges:
                        (retval, isBendUp, bendAngle) = component.flatPattern.getBendInfo(BRepEdge)
                        msg = f'\tretval:{retval} isBendUp:{isBendUp} bendAngle:{bendAngle}'
                        app.log(msg)
                        adsk.doEvents()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
john.kirchner
Thank you for providing the f3z + image, I was able to reproduce this and identify the issue. Will get this fixed!
gvisca44
in reply to: john.kirchner
Thanks John.
Is there somewhere I can track the fix ? Or will I receive notification ?
john.kirchner
Unfortunately we don't have any public facing bug fix tracking, this specific fix should be out within the next month or so though.
In the meantime one workaround I can suggest is to compare the flatPattern.flatBody.faces.count (shouldn't crash) to the component.bRepBodies[0].faces.count - the counts are equal, then that means there are no bends in the flatpattern.
Technology Administrators
