Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Can't edit Python scripts
7 REPLIES 7
Message 1 of 8
Twernmilt
1166 Views, 7 Replies
When I click "Edit" from the "Scripts and Add-ins" dialog, it doesn't open VS Code. Instead it opens another copy of Fusion 360.
The log says there is an error, but it doesn't say what the error is:
20191031T162958 I error happened when enable attach VSCode:
20191031T162958 I
7 REPLIES 7
Message 2 of 8
JesusFreke
in reply to: Twernmilt
Was this on a Mac by chance? That sounds suspiciously similar to the behavior someone mentioned when they were trying to get PyCharm to attach to the Fusion process on a Mac  (here).
Message 3 of 8
Twernmilt
in reply to: JesusFreke
I am on a mac. Sorry, I forgot to post my platform.
Specifically I'm on a Macbook Pro running macOS 10.15.1, but it also happened before I upgraded yesterday.
Message 4 of 8
Twernmilt
I've got it working now. Thanks for the link. I told macOS to open all *.py files with VS Code, which got it running.
Message 5 of 8
Twernmilt
Well, it looks like I spoke too soon. I did get it working briefly, but it went back to the old behavior once I created my own script.
Message 6 of 8
Nilesh.Mohite
Hi @Twernmilt ,
It is issue with latest python extension installed in VSCode.
Please refer to the following similar issue.
API debugger doesn't work after Oct 2019 update
Solutions provided by @goyals will work for you. Go to Solution.
Let us know if you need more help.
Thanks & Regards,
Nilesh Mohite
Nilesh Mohite
LinkedIn
If my answer helped you, please use  ACCEPT SOLUTION .
Also be generous with Likes!  Thank you and enjoy!
Message 7 of 8
I have same issue on my mac. It did not help me to change the systemwide file association of .py with VS Code though. It still only launches a second instance of Fusion.
Message 8 of 8
Nilesh.Mohite
Hi @Anonymous ,
This is due latest python extension installed in VSCode. You need to downgrade extension to lower version 2019.9.34911.
Thanks and Regards,
Nilesh Mohite
Nilesh Mohite
LinkedIn
