08:57 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to access a selected item from a Text Drop down text box and use that as a key to a dictionary that will influence the input types I fill a second tab with.
However no item seems to be selected even though there was a change that activated the handler. How do I access the selected item in this list? Is it possible or are there work arounds?
Here are the handlers in m
class InputChangedHandler(adsk.core.InputChangedEventHandler): def __init__(self): super().__init__() def notify(self, args): try: command = args.firingEvent.sender cmdInput = args.input if cmdInput.id == 'ObjectTypeSelection': ui.messageBox('Input: {} changed event triggered for Object Selection'.format(command.parentCommandDefinition.id)) inputs = command.commandInputs ui.messageBox("Input is valid: "+str(cmdInput.isValid)) objectItems = cmdInput.listItems selection = None for item in objectItems: ui.messageBox(str(item.name)+"selected = "+str(item.isSelected)) if item.isSelected: selection = item break ui.messageBox("selection: "+str(selection)) tabCmdInput2 = inputs.addTabCommandInput(commandIdOnPanel + '_tab_2', 'Define your ') # tab1ChildInputs = tabCmdInput2.children except: if ui: ui.messageBox('Input changed event failed: {}'.format(traceback.format_exc())) class CommandExecuteHandler(adsk.core.CommandEventHandler): def __init__(self): super().__init__() def notify(self, args): try: command = args.firingEvent.sender ui.messageBox('command: {} executed successfully'.format(command.parentCommandDefinition.id)) except: if ui: ui.messageBox('command executed failed: {}'.format(traceback.format_exc())) class CommandCreatedEventHandlerPanel(adsk.core.CommandCreatedEventHandler): def __init__(self): super().__init__() def notify(self, args): try: cmd = args.command onExecute = CommandExecuteHandler() cmd.execute.add(onExecute) onInputChanged = InputChangedHandler() cmd.inputChanged.add(onInputChanged) # keep the handler referenced beyond this function handlers.append(onExecute) handlers.append(onInputChanged) # Keep the handler referenced beyond this function inputs = cmd.commandInputs # Create tab input 1 tabCmdInput1 = inputs.addTabCommandInput(commandIdOnPanel + '_tab_1', 'Object Type Selection') tab1ChildInputs = tabCmdInput1.children dropDownCommandInput = tab1ChildInputs.addDropDownCommandInput('ObjectTypeSelection', 'Select an Object Definition', adsk.core.DropDownStyles.TextListDropDownStyle) dropDownItems = dropDownCommandInput.listItems for objType in {"Bolt":"stuff"}: dropDownItems.add(objType, False) ui.messageBox('Panel command created successfully') except: if ui: ui.messageBox('Panel command created failed: {}'.format(traceback.format_exc()))
y code. Bolt should be shown as selected.
