Hi, I'm reposting this for votes again because it was archived and I really think its a good idea, and easy to implement.
I'd really like a feature under "construct" to define points by just entering XYZ coordinates in a table (cylindrical or spherical too I guess). This is quite useful for quickly importing measurements that are taken manually (survey data, CMM, locations in customer specs etc.) A fourth column for point name, which is displayed on the model (with the ability turn names on and off) and after mouse over would be quite useful too.
Ideally I'd like to be able reference these points against multiple coordinate systems, but just referencing the origin is fine for now. The "Offset CSys Datum Point" tool in Creo is similar to what I'm looking for.
There are also several other ideas around about work coordinant systems that really could use another look too and could probably be done at one time without much work. Simple reference geometry creation really hangs up a lot of professional users.
