This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
Welded Frames (Weldments) similar to Solidworks
In Solidworks, a 2D or 3D sketch is created.  You then choose your frame material from a list of common profiles (such as 1" X 1" X .125 angle iron or 2" X 0.625 wall tube).  The profile then gets extruded along the lines of your original sketch.  There are simple options for adjusting how the orientation of the profile and for controlling what happens at the corners.  Cut lists are automatically generated from the model.
This is a fantastic tool for welded frames, but I have also modified it for use with construction projects and dimensional lumber.
I am sure there is similar functionality in Inventor, but I have no experience with it.
13 Comments
TrippyLighting
Yes, that is another one of the many machine building prodictivity features in SW. Works also perfectly well for extruded aluminum profile frames.
This would be really great when they make some improvements to 3D sketchesSmiley Wink
OahuPilot
Frame generator from Inventor is really missing from fusion 360
promm
Status changed to: RUG-jp審査通過
@nowak_nick,
Thank you for your idea.  Although it is a great idea, the amount of time it will be before we get to it is the reason why the idea is being changed to Archived.  Weldments is a very large project for the team and with our current roadmap it will be years before we explore our options.  At this time, we will revisit your idea.
Thank you,
Mike Prom
Years? Really? I've already spent years learning your software, waiting for such a feature, assured that Inventor can do everything Solidworks can do and visa versa.
No offense intended guys, but this isn't something to put on the back burner.
I also depend on weldments, to design frames and chassis. In particular I have my custom libraries for steel tube thickness. It's hard to imagine why they would be so hard to code, since conceptually it's just a set of profiles used for extrusion.
benguestN73BB
One more reason why Fusion 360 is just a toy. It will get you 80% there, but it's the last 20% that makes the difference. I'm a huge proponent of 360, but not having a weldment tool like SW is a no go for our shop.
TrippyLighting
@benguestN73BB
Fusion 360 might currently not support weldments but that does not make it a toy.
It has plenty of functionalities that make it usable for a broad range of businesses.
jared.szechy
Observer
Weldments is a much needed feature, until it's available in Fusion 360 I'm forced to continue using SolidWorks.
Is there hope that a weldment profile feature as in SW is on the roadmap now?
marc.a.grossman
Honestly, weldments can't wait a couple years. We need a roadmap on this. I like a lot about fusion360, but it is missing some critical functionality. I'd have to up-vote the idea that fusion360 is "just a toy" until weldments and good sheet metal are added.
Where fusion360 is great is CAM. You can't even get decent CAM packages for the price you can get the entire fusion360 software package that includes CAM.
This is back on the feature request list.  See the following and vote!  This is a super important feature and the only reason I'm not committed to Fusion 360.
https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/fusion-360-frame-generator/idi-p/710...
egemen1600
Forget weldments, just improve Pipe command a little bit. In fact, just add a seperate width and height option for square.
