Fusion360 is also aimed at amateurs that like to design and 3D print, correct? One of the important things to consider during 3D printing is the minimum wall thickness. Shapeways has some very neat online checks and tools to check the files. However, these tools can only be used after exporting and uploading your 3D model to the Shapeways website. Therefore, I think it would be awesome if Fusion would have a wall thickness checking feature. The user should be prompted to set a minimum wall thickness (ideally seperate values for supported and non-supported walls), and Fusion highlights problematic areas.
Image: Shapeways wall thickness tool. Safe areas are green, problematic areas are orange.
