The Loft tool is one of key modeling operations in F360 for my work but there are some features that are missing.
For now I will talk about the most important one that you should add as soon as possible... The possibility to control the curvature continuity of the rails and not just the profiles.
Most of the times I perform lofts inside a surface patch layout in which all sides are edges (not curves) and all sides should be tangent.
Currently I'm faced with many cases in which I have the rails sides breaking the curvature continuity even if I add many profiles whose curves are tangent to projected curves on the targeted surfaces. The result is not aceptable because even small breaks will be noticed if the part is prototyped or a mould is made to manufacture it.
Best regards,
Carlos
