Show only
Search instead for
Working in the Model or in the Patch, I feel the lack of a tool like the sweep or two rail curves the most comprehensive network ... obviously with all the solutions of tangency and more.
Well, my comment is to agree. Sometimes you want a swept profile to change orientation- to keep consistently oriented to those organic shapes Fusion lets us make, for instance. Having two rails is a good way to accomplish this.
I'm finding myself frequently needing a way to make a profile/shape/sketch to follow not only a path but a "rail", or 2 path lines/edges. This would give more control over not only the path of the duplication but also influence the objects scale/rotation based on the relationship between the rails/paths (in a similar way like when you change the size/rotation of the segments in a pipe... the entire pipe shape is influenced)
One way I think this could be implemented is by using constraints. I have found a few work-arounds by constraining a sketch between two lines. Then copying or path following one of the lines and setting up constraints for both lines. Then when I move one of the lines, the duplicated sketches/bodies with change scale/ rotate based on the constraints set.
I see other programs with this function. I think even Inventor has a similar tool. I think this would be a great addition to Fusion and open an opportunity for creative designs!
What you have to understand with fusion - and that is true with solid works inventor pro-e - you sketch in 2d planes and thus you need to structure your work differently. This is more labor intensive but afterwards you can change many aspects better than in Rhino. In Rhino you would have to restart.
However I agree that it would be nice to have more freeform drawing abilities like in Rhino - specifically for making fast concept models that approach is solid!
This is a must for me, I was considering fusion 360 for my modeling needs but was amazed to find out that this is missing. I have to look elsewhere because of this.
