Show only
Search instead for
Hi, i've found this issue when lofting surfaces. If the option "smooth" is activated, only surface continuity is ok, but not the edges. Here an example:
This drove me insane more than once and I finally ended up getting moulds cut and moulded parts made with creases in them because F360 wouldn't work right.
Totally agree that there needs to be more options about how edges and iso-parms are handled in Fusion. Still not enough control over how lofts propagate.
Thank you for your idea, we have plans to better control edge continuity with our loft tool. When work gets started this will be changed to future consideration.
