Currently the Fusion importer assumes that an stl is in centimeters with no option to change it - other than scaling once open.
I would like to see an import dialog box with the option to set the units in cm, mm, inches, as well as setting a user defined scale.
I would also like to see files retain their file extensions after import.
Robbie Halvorson
Sr. Designer
Boston Scientific
