This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. Translate
shrink wrap / convex hull
This would let you select one or more bodies or faces and generate essentially a tight, shrink wrapped plastic boundary that surrounds them.
Ideally this would be implemented as a convex hull but with parameters to allow the user to specify clearances around objects, maximum bend radius to avoid sharp corners, and a way to turn the corners to control points for a spline or NURBS like organic surface.
Very useful for designing shells and fairings and the such.
Please vote for it this time, people. Literally costs you nothing.
