Making multiple holes in fusion 360 is a very satisfing function, select your location, decide the type ,size, depth, hit enter and done. I would Like this trick apply to installing multiply screws with the proper animation of righty tighty and lefty loosey. The current animation shows install screws turning anti-clockwise ( should be clock-wise). I would like to select multiply location select my screw type, size (especially if the screws are all the same size) and have them all installed at the same time. Seeing the animation of a screw installed for the first time is amazing, doing that a hundred times and the fun turns into enough already I am done with this. Thanks
