This is an idea previously submitted: https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/scale-sketch-based-on-first-placed-d....
However, I would like to reopen this, as I find this a really useful feature in Inventor and it would be good to see this transfer over to Fusion 360.
The problem is that if you freehand a sketch, with no sizes, to rough out the shape you want, then as soon as you add the first dimension it gives the sketch some sense of scale. If you have freehanded the sketch very small and then apply a sketch which is 10 times bigger, then it can deform the sketch geometry, trying to maintain its constraints etc. This means more time rearranging the sketch, before you can add any more sketch dimensions. The same problem we had in Inventor, until they added this feature.
See example below:
