Show only
Search instead for
When a shape is drawng, it might not be sized correctly. Adding a dimension to an entity may make the sketch blow up if the size changes too much. It would be nice if the entire sketch would scaled based on the first placed dimension.
Thanks for the idea - There are technically challenges with our sketch kernel that we need to resolve so that the sketch behaves the way you are describing, hence why I'm archiving this for now. Definitely appreciate you capturing this. Also, Ideas with 10+ votes within a month are reviewed by the Product Management team for future consideration. If you feel strongly that this is needed, please resubmit with more detail on why you think this is valuable to Fusion 360 users so that the idea gathers increased support from the community.
