Show only
Search instead for
Submitted byAnonymouson09-30-201612:11 AM
Status:
RUG-jp審査通過
remove construction lines for laser cutter on DXF export
Currently I have to make 2 versions of every sketch that goes to a Laser cutter, because construction lines will come in as cut lines, If I have to make changes It really slows down the workflow.
If you haven't turned on the preview for water jet/laser/router, please do. You have two options for sending your designs to machines if you want more control over what is exported. One option is to create the passes in CAM and export the G-Code to the machine and the other is to use the dxf export inside of CAM.
