Ratio Joint
Ratio Joint
A simple ratio joint between two other rotating joints to create a simulated gear or belt drive set. so if component A rotates at 10rpm and the ratio is set to 1:2 component B rotates at 20rpm.
2 Comments
HughesTooling
You can do it now using motion links.
Mark
Thanks, I was not aware of this function.
